No Forward Gears. Just reverse.
Well....
Was driving, got on the throttle, (car was warmed up). And it went into a "false neutral" let off. Rolled back on it, and it was fine. Well came to a stop, and BAM....No More forward gears. I only have reverse, and reverse works great (drove home 3miles in it,lol)
Pan was really hott. I unpluged the harness to see if its a solenoid problem, and same thingt. No no forward,just reverse. Trans has been fine latley. No slipping.
BUT, It has hit a "false neutral" or would jump out of gear and I'd let off, roll back on, and it was fine. it only did thing from a 40+ roll and a dead stomp on the pedal. Also I'd get a slight shutter from a slow take off or around a corner.
It didn't seem to start happening til I pulled the pan to replace the 3-2 down shift solenoid. Also the converter wouldn't lock up.
I don't have a scanner, so I cannot pull codes.
Same happened to my formula, one of my torrington bearings came apart and spread throughout the trans. Ended up having to get another case because i couldnt pull it all the way apart.
