Intake decision
Old 03-08-2009, 11:29 PM
sofla71chev's Avatar
Default Intake decision
I am building a 78 Malibu 3200# with a 6.0l in it and am trying to decide if I need the Super Victor over the JR. So far my setup is
LQ4 stock bottom end
Comp cams 230/234 .605/.613 w 113lsa
Patriot Stage 3 LS6 heads
1 7/8" long tubes.
Powerglide w/3500rpm stall
3.70 9" 275/60/15 m/t
Accufab 4 barrel throttle body for efi, 42lb injectors
Nitrous big shot plate system, with a small shot until I get a forged bottom end.
The car is going to be setup more for track then street but will see a few weekend drives. I would just like to know which intake would suit my car better. Also does my cam seem a little small, id like to be in the mid-low 6's in the eighth.
Any suggestions would be appreciated, thanks.
Thanks
Old 03-09-2009, 01:42 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I would go with the Victor Jr, your set up really isn't too radical for the Super Victor
Old 03-11-2009, 05:32 PM
Okay so assuming I get the Victor jr, with the suspension working correctly might I be able to do mid to low 6's in the 1/8th, Or will I really need replace my little cam. Thanks for the response
Old 03-12-2009, 06:53 AM
Z28/2002's Avatar
I would PM Patrick G and shoot him $25 to spec out a cam for your setup
Old 04-07-2009, 06:34 PM
Well I now have a Victor Jr , Accufab 4500 throttle body and wilson 4500-4150 adaptor, So I am thinking I need to trade away my cam for a bigger one.
Also the instructions on my lingenfelter oil pump says it will not work with a double roller timing chain. Which I have, so I need to figure out how true that is, or order a LS2 chain
