daily driver want to shut 03 cobras up
i have a daily driven 98 z28 and want more power but don't want to sacrifice my fuel economy because i am fixing to go back and forth about 60 miles i am wanting cam and may be heads. also what are the different casting numbers on factory heads mean? thanks lots
i know it's just temporary power but have you thought about the juice ? if you don't want to run spray but still outrun a terminator car i would be looking for no less than 440-450 rwhp and even then i would only race pullied ones.your mileage/driveability will suffer some,it depends on how good the tune is on how much it will suffer. just my $.02
^^^ Regular Cobra a h/c ls1 will handle no problem but get one that has been modded and pumping out 500rwhp and you'll need more than just h/c.
I can set you up with a H/C package that will give you all you need to handle a regular one but you have to realize there is always a faster car out there.
it is a little moded with pully exhaust. but the other is twin turbo but i dont think he will last long i like the sound of cams but im just woundering about heads but i want a good daily driven cam to
Even the big cams can be daily driven, but need a good tuner. A pullied cobra with exhaust and a tune will net around 450-500whp. You will need 450whp to compete with it, so a good h/c is manditory and a small bottle(75-100 shot) will teach him a lesson easily. You can still get decent gas mileage(20-25mpg) with a h/c, just as long as you are tuned for it also.
with a solid h/c setup i would also want to put on a fast setup which would be another 1200 bucks on top of a 3000$ h/c setup so it will be quite a bit of money to do it right. personally if i had to do it again and i wanted 450-500 rw and good driveability i would start looking for a good used p1/d1 procharger setup.
EDIT he has a 231/237 cam, i forget who made it its old but proven.
I have seen a pullied cobra with full exhaust be door to door with a mild/heavy cammed with TFS headed GTO. Some are stronger than others, and depends if you are racing a good driver. He is looking to be able to teach a lesson to the guy. You need really good power to do that.
if you really want to teach him a lesson you need a s/c or t/c with 10lbs of boost. h/c will get a stock one for sure, hell a bolt on ls1 can almost keep up with one on the hwy. you will need 500+ at the tires to not worry about wasting a cobra.
witch is better ls6 heads or Edelbrock xtreme heads found a set of ls6 for $537.60 with out shipping would it handle 500 hp? kinda decided against fuel economy. if anybody has 500 hp what is your mpg? pls help
