How Do You Have Your Fuel Lines???
Old 03-09-2009, 03:51 AM
InsaneDomestics's Avatar
Default How Do You Have Your Fuel Lines???
I have a 98 Camaro and I have the Aeromotice Fuel System and Im trying to come up with a few options on where to run my new fuel lines. Any ideas would be helpful. Thanks
Old 03-10-2009, 09:07 PM
theblur98ss's Avatar
I just ran them along the brake lines where the stock fuel lines were. I have seen cars that took them inside the frame and brought them out up front. I with I would have looked closer to see how it was done.
Old 03-10-2009, 09:12 PM
chevyz2801's Avatar
look in the stickies
Old 03-10-2009, 09:41 PM
barnat's Avatar
Heres mine being feed on the passanger side threw a filter and i mounted the fuel reg on the drivers side which returns from there threw that protective metal thin plate mounted down low near the steering shaft that hides the brake lines and stuff and keeps the return line away from the exhaust! I looked a 100s of setups before i picked this way!Its the cleanest and simplest
http://s243.photobucket.com/albums/f...erhood%20pics/
Old 03-11-2009, 09:33 PM
formerly turbo4.8 (2014-06-25)
BLKSSLTT's Avatar
wherever you route them... make sure your fittings are easily accesible. just incase one starts to leak
Old 03-11-2009, 10:39 PM
ak95ta's Avatar
Here are a few of mine, The A1000 mounted in the frame rail
From underneath
With the tank.
The filter and stuff
Here I put it where the factory put the LT1 lines under the driver side.
Came up the inner fender and drilled 2 holes, supply and return
Then into the engine compartment.
Old 03-12-2009, 04:07 PM
Is that one of the tanks from Nasty Performance?
Old 03-12-2009, 06:15 PM
ak95ta's Avatar
No, it is a Speed Inc fuel cell. I bought it used for $100. They are very similar though.
Old 03-12-2009, 07:33 PM
chevyz2801's Avatar
you got one hell of a deal looks good
Old 03-13-2009, 02:16 AM
nemss1's Avatar
i havent been able to find the speedinc tank on their site???
Old 03-13-2009, 11:30 AM
ak95ta's Avatar
Yea, I don't know. I bougt it used about 2 years ago, and it may have been a year or 2 old. You might have to contact them, as they may be build to order.
Old 03-13-2009, 01:30 PM
nemss1's Avatar
ok, thanx. ya i tried looking up that tank and couldnt find it. i will just contact them like u said and see what they say
Old 03-14-2009, 08:38 PM
code4's Avatar
here is one for sale:
https://ls1tech.com/forums/lsx-parts...alum-tank.html
Old 03-15-2009, 09:02 AM
nemss1's Avatar
i heard something about stock exhaust routing probs with the speed inc tank. someone fill me in on that
Old 03-15-2009, 11:39 AM
chevyz2801's Avatar
has anyone ran steel or aluminum fuel line instead of braided line
Old 03-15-2009, 03:16 PM
ak95ta's Avatar
Im running a 4" Mufflex with a spintech muffler with no problems. I actually have all the factory heat shields in place.
Mine is mostly aluminum. There are just some places you have to have braided.
Old 03-15-2009, 08:38 PM
11Second Club
Gauge's Avatar
I ran my return along the stock feed line. There were a couple points where I deviated a few inches to avoid proximity with the exhaust, but for the most part I followed it the whole way. Towards the front, I tucked it under all the heat shielding for the stock feed line that I could manage to stuff it under. It turned out pretty good, I think.
Old 03-15-2009, 10:07 PM
chevyz2801's Avatar
Do you have any pics and what size line did you use?
Mine is mostly aluminum. There are just some places you have to have braided.[/QUOTE]
Old 03-16-2009, 12:47 AM
ak95ta's Avatar
I used 5/8"(10AN) for the feed and 3/8"(6AN) for the return. All of the pics above are mine, were you wanting something else?
