yella terra rockers with 98 heads?
Old 03-09-2009, 07:22 AM
MagnaTransAm0098's Avatar
Default yella terra rockers with 98 heads?
do the yella terra rockers normally fit in the heads with perimeter bolt valve covers? Or are my valves just taller.. By the looks of it I would need the valve cover spacers.
Old 03-09-2009, 12:03 PM
vettenuts's Avatar
How are they shimmed?
Old 03-09-2009, 08:45 PM
well the heads aren't on the motor, i was just checking some things and set one in place, there wasn't any shims. I just simple set the rocker in as it would normally be placed, again not shimmed. Shimmed it will be even higher..I know the heads have bigger valves but I guess they are taller to. I think I may just use the stock rockers and sell these, from what Ive concluded they arent going to help with valve train noise all that much.
