Another 1000 rwhp TT GT35R C6Z
Hi Guys,
Here is another build we did for a customer using the same package that we went 210mph with in the texas mile last october
basic setup consists of:
LSx Block
APS C6Z kit
Callies Rotating assembly
Diamond custom pistons
Stock LS7 heads
Upgraded valves and valvetrain
Tilton triple carbon clutch
G7xT turbo cam
2000 hp fuel system (injectors, pumps, wiring harness, rails)
Meth kit
These pulls consist of 5 gallons of PUMP and 5 gallons of 100 octane
Boost level is 17ish on the 1080 pull, and 14ish on the 1010 pull, still a lot to go, but the dyno isnt holding it anymore.
We had one major hold up with this car that took an extra 4 weeks, but completion of this car from start to finish, including the unforseen wait was tick over 12 weeks. With out the wait, we can have these cars in and out in 8 weeks now
Louis
LSx Block
APS C6Z kit
Stock LS7 heads
G7xT turbo cam
Meth kit
Louis
working up to the tune, start at 1500-2500, then 1500-3k, then 1500-4k, work up on the cal, never do a full pull till the end, 5500 is as far as I got. Its back on the rack being buttoned up Pulls at 1000rw go FAST! I takes 4-6 guys to do a pull- 2 in the trunk, 2 watching inlet ducts/engine bits and 1 logger, and one dyno operator
Pulls at 1000rw go FAST! I takes 4-6 guys to do a pull- 2 in the trunk, 2 watching inlet ducts/engine bits and 1 logger, and one dyno operator [/QUOTE]
The pulls do go quick! I don't understand the reason for the guys in the trunk if the car is strapped down well enough?? I have watched this TT 1200rwhp C6 dyno with no people in the trunk and hold just fine. I guess it's all in how it's strapped down??
[/QUOTE]
Also depends on how much tread is left on the dyno rollers themselves.
-Wade
AWESOME numbers. Looks like a nasty build! Intrested in the engine.
Whats the CI? & CR? Looks like you used the LS7 intake? Lifted the heads?
Also turbos were used? Sorry i am not fimilar with that kit...
If it's not a secret.
Louis, we have a customer using the APS kit now on a C6Z, he is wanting to go to TC76's. I might send you one to try to fit in....any chance you could take a look??
amazing work again Louis and the LG team! i seriously think you guys should gfit this engine intio one of your race cars and go. then take it to the 'Ring in germany and show us all how to build really fast cars! im thinking sub 7 min should be do-able! hehe
is there any reason for using the LSx over the warhaek or even stock LS7 block??
Chris.
Chris.
