head bolts
Main reason I tell you this is because of my past experiences with stock bolts and my old block from my first build. USE ARP STUDS.
With your current mods, stock head bolts are okay(make sure they are new) never reuse the old ones. As you progress in your upgrades keep the studs in mind....much easier to remove and reinstall the heads for any reason you might need to.... depending on mods Nitrous, Turbo, Procharger, they are added strength and better clamping force for you.
Stock MLS gaskets is fine for what you are doing.....I have them on my 383 and have had no issues.
