TFS 215's with morel lifters what pushrod length??
Old 03-09-2009, 06:30 PM
need4z's Avatar
Default TFS 215's with morel lifters what pushrod length??
I am going to be ordering the morel link bar lifters for my cam/head swap this spring. Now from what I have read, you need to go with .050 shorter pushrod with the morels. So with the TFS heads requiring a .100" longer( 7.5 pushrod), with the morel lifters, would that mean that I am gonna need a 7.45" pushrod?? Should I just wait until I have it all together with a pushrod length tool to properly measure?? Would kind of like to know before hand if all possible. Thanks
Derek
Old 03-09-2009, 06:40 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Do it right and measure. You can try and do the math, but it's like installing a door in your house, just because it's 'supposed' to fit, doesn't mean it will.
Old 03-09-2009, 06:47 PM
vettenuts's Avatar
Measure. Your numbers are off by the way because the Morels are taller and use a different preload. Pushrods should be you last purchase.
Old 03-09-2009, 08:27 PM
need4z's Avatar
yeah sorta expected to hear that guys. I knew you'd be here vetttenuts. haha It will have to be the final thing bought. One thing. I have only ever done lash settings on old sbc with solid cams. Do you use a feeler gauge at all to measure lifter preload here?? Sorry not familiar with these late model hydraulic roller set ups yet. I will be all NOOB when I start tearing into the motor!
thanks
Derek
Old 03-09-2009, 08:33 PM
vettenuts's Avatar
Couple of ways you can do it. Easiest is to set cylinder #1 to TDC then install rockers snug and measure zero lash. Add lifter preload to zero lash length.
