New noids?
Old 03-09-2009, 09:09 PM
blockheadnic's Avatar
Default New noids?
I have been debating weither to replace my HSW noids or not. they are a year old and work fine but the first time i set up my system the purge solenoid engaged and would not close.
Should i be safe and replace them , and if so with which brand?
I am spraying 150 wet and maybe run a bottle through it a month.
Old 03-10-2009, 12:00 AM
Nitro Dave's Nitrous Outlet's Avatar
I would just check them and make sure they are both still firing good and strong. If you have the small base solenoids the size of your thumb and you just want the assurance of a better solenoid the Larger Higher flowing Nitrous Outlet Solenoids are hard to beat.
They will take more abuse, flow alot more, and open under pressure when some of the smaller base solenoids will not.
Dave
Old 03-10-2009, 09:24 AM
Mike@HSW's Avatar
Sounds like they have treated you well thus far. Was there a wiring issue with the purge when you originally set it up? If you would like, you can send us your noids and we will take them apart and inspect them. Its always a good idea to rebuild your solenoids every so often. I am not sure which ones you have, but you can always upgrade to our large solenoids if you like.
Old 03-10-2009, 12:34 PM
Well it wasnt the wiring because i swapped coils and it did it again. i have the little solenoids so i should upgrade to something bigger.
Old 03-10-2009, 01:05 PM
TARZAN's Avatar
C'mon guys, you should be asking this stuff...
Do you run a nitrous filter?
-Will
Old 03-12-2009, 09:50 PM
-Will
Good point............................................. .................................... may have trash under the piston...
