New LS1 Owners - Newbie Tech - No X or H Pipe??
View Full Version : No X or H Pipe??
71-Camaro-98
03-09-2009, 10:52 PM
I have heard of a few people running exhaust straight back (TD) without using any kind of linkage ( H pipe or X Pipe) to connect the exhaust to even flow and pressure from one side to another. Is this able to be done without having any negative effects? Is it just a bad Idea all around. Or are there really no positive or negative effects to doing this?
FiredUpZ28
03-09-2009, 10:54 PM
I would use a crossover. Helps with scavenging.
1SLwLS1
03-09-2009, 11:01 PM
scavenging is the whole point of TD with an X, its a waste of pipe any other way IMO
71-Camaro-98
03-09-2009, 11:11 PM
If I can get a more detailed definition/explanation I would appreciate it...
FiredUpZ28
03-09-2009, 11:14 PM
Scavenging is basically the exhausts ability to literally pull itself out of the cylinder, leaving more room for air/fuel to enter. Crossovers even out exhaust pulses and help to speed the exhaust up..
1SLwLS1
03-09-2009, 11:20 PM
theres no real damage that can be had but the bank's pressure cannot equalize. This is just not optimal, thats all. Scavenging takes place when the exhaust pulses/gases from one bank go into the x pipe to the adjacent bank, it creates a vacuum in that other bank which helps to pull exhaust out instead of the piston pushing it out.
FiredUpZ28
03-09-2009, 11:23 PM
^ Yup
71-Camaro-98
03-10-2009, 02:57 AM
Sweet, just what I was looking for, thanks for the replies.:thumb:
01ssreda4
03-12-2009, 06:37 PM
this guy doesnt have a crossover of any kind.
http://www.youtube.com/watch?v=bz1qa-ZMTrs&feature=channel_page
