Conversions & Hybrids - Car has to learn to idle everytime I start it
1987earthquake
03-10-2009, 02:37 PM
I have a 5.3 from a 1999 z71 in my 87 camaro. I swapped the cam to a 222/222 Lunati and put some comp 918's on it. I don't have a vacuum reserve canister on it. Do I need it and if not, does anyone have an idea of why my car would die like this.
Eric Anderson
03-10-2009, 03:01 PM
Perhpaps elementary, but.. do you have constant power to the computer? If you had keyed power to the computer it would act this way...
streetassasin
03-10-2009, 03:03 PM
is it tuned?
1987earthquake
03-10-2009, 03:07 PM
Checked all power and grounds all are correct. Always good to start there.
1987earthquake
03-10-2009, 03:10 PM
is it tuned?
Had a mail order tune done. I know I need to get it done locally but I wouldn't think it would have that great of an effect.
Any other ideas?
Pulling any codes? IAT sensor functioning properly?
ls1_chevelle
03-10-2009, 04:09 PM
I'll put 5 bucks on it being that your 12volt orange which always supplys power to the PCM is on a switched circuit. It needs 12 volts all the time.
I go through this every time my car goes through tech and they hit the battery cut off LOL. It was a pain to run a wire all the way to the trunk. So I deal with it lol.
ls1_chevelle
03-10-2009, 04:10 PM
word.
1987earthquake
03-10-2009, 06:29 PM
took it by autozone and got them to scan it. Everything was clear.
1987earthquake
03-10-2009, 06:31 PM
I've checked this a couple times. That's what I kept thinking. give me a list of pins that should be hot all time and a list that should be keyed. I will check this again and see.
crzytown69
03-10-2009, 06:46 PM
x123456789
bczee
03-10-2009, 06:54 PM
Make sure your battery and alternator are in good working order, check to make sure your +12v lead to the PCM is not going to the Switch Ign switch, it should be connected directly to a +12volt battery source.
else maybe your PCM is bad.
1987earthquake
03-10-2009, 07:59 PM
battery and alternator is good reading 14 V on my gauge and never has a prob starting. and that's with the battery in the back. If the pcm is bad would it still run right otherwise?
02gtp4now
03-10-2009, 09:32 PM
my car acted like this also the o2's were bad causing it to have to adjust itself every time it went from closed to open loop
