Lets talk direct port
1. What size tubing is ideal for after the dist block? 3/16?
2. Is there a speacial type line for doing these applications such as double walled brake line?
2.5. If there is a different line where can the line be purchased from?
3. Is there any support bracket for the dist block or does the block support the lines off the hard lines?
4. Is there a kit for tapping the intake manifolds where it be a sheet metal intake or a composite.
5. Is one noid fine for the whole set up or is it better to have seperate noids for each set up.
6. When doing a direct port kit like this is who of the owner to install EGT sensors in all the primary tube of the exhaust to get accurate reading on each cylinder?
7. When doing a set up like this how far colder plugs should you go too? Or does that depend on the size of the shot.
8. Best place to buy a dual split block meaning nitours on the top with 8 outlet and then fuel on the bottom with 8 outlets. HSW has a few dist blocks but they are only four nozzles. And they will get pricey to do it that way.
9.What type of flares are used in such application double flare, iso
This is going on the serect build motor. LS2 block forged internals.
are you serious?? Why dont you just buy a whole kit. By the time you do all that half *** stuff you just listed, you could pick up the phone and just order a new kit...
Yes, 3/16" is most common
You want annealed stainless steel
Summit sells rolls in varying lengths, I used 20ft for my DP install. A few of the sponsors sell pre-cut lengths with one end flared already.
No support bracket, the hard lines hold everything up.
You just need a tap (and correct bit size) for your nozzles, 1/16" NPT is common. A few of the sponsors sell them if you can't find locally.
Depends on what solenoids and how much you're spraying.
Depends on size of shot, compression ratio, fuel octane etc. TR6 or one step colder are most commonly used here.
Nitro Daves has one, this is the one I used on my kit:
http://www.nitrousoutlet.com/catalog...roduct_id=2832
37 degree single flares, get a good tool because the stainless will tear up cheap tools
