heads for boost
That's still based on a stock GM casting with a 1/4" deck thickness. AFR's, ETP's, Trickflow's, Darts, have thicker decks for lots of boost. 3/4" if I remember correctly. I would think 10-12 would be safe on stock heads would be ok, but after that I would get different heads. Another thing to remember is that the Darts are pretty cheap and have that thick deck. Do a little bowl work and a good valve job and you are into them less than $2g's.
i would get some lq9 heads if you are working on a budget. i would stick with a head that has big combustion chamber, 72cc and up. you want a big combustion chamber because it will prevent knock better then a lower cc head on a same CR motor.
We've run 16 psi quite often with Patriot's stock thickness heads with ATI ProCharger superchargers, and we've never had a problem at that boost level.
This Corvette has seen a brutal environment on a road course with 16 psi of boost and Patriot heads. http://www.exoticperformanceplus.com...Car.php?car=54
Same car now with an F-1C. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
1/2 ARP studs or OEM size?
What head gaskets?
