help me t-shoot
help me t-shoot
here is my setup https://ls1tech.com/forums/introduct...61-so-cal.html
my motor has a nasty dead spot only at a certain rpm range around 1-3000 rpm it just loads up real bad and almost sounds like it is detonanting. so bad i cant even get the car to move, and then it will eventually clear out after i get the rpms up but it takes alot to get them up. this problem only exists when the engine is warmed up, specifically 150 deg on the water temp. runs good before it reaches that temp.
recent maint was plug change, so i out the old plugs back in same problem. was running race gas so i switched to 91 same problem now i have a mix of 91 and race gas.
i cleaned up the injector wires and alot of the harness wires on the engine since alot of them were just hangin, but everything is plugged in and all wires wiggled still the problem exists.
ive changed fuel pressure from 35 to 60 psi and it seemed to get a little better on the lower end of the psi range..
my buddy has had his scan tool on it and tested all sensors and injectors with no issue?
im lost
im lost
