A4 Brake Pedal Assembly
9 Second Club NA
Re: A4 Brake Pedal Assembly
Im interested in this too...it just doesnt look right with a little brake pedal right next to the gas pedal and all that space to the left of it. (if I was to remove the clutch pedal) I want it to be original and in place. If both the clutch and brake pedal (manual) was to be removed, will the A4 brake pedal bolt right up? If not, what has to be done? Thanks
When I did my swap I swapped the whole assembly out. It was an even trade.. I looked on my parts CD and there is so many parts making up the assembly. You might be better off in a junk yard, or parted out car.
The assemblies look totally different when you look at them.. I do not know if the pedals will swap in and out.. I do know that the assemblies mount totally different.
9 Second Club NA
So you actually swapped the entire clutch and brake pedal over to the automatic brake pedal? If so, how hard was that and could you briefly explain? I personally rather have the auto. brake pedal in there so that it looks like it came that way and doesnt look out of place. Thanks
I swapped the whole assemblies with another car.. I was swapping M6 to A4 and he was going the other way.
Basically there are about 10 or so bolts (Gold 14mm I believe) that hold the whole assembly in.. On the M6 there is one right above the steering column that is a bitch to get off. Once you get all of them out, the assemblies come out in one bracket/piece
9 Second Club NA
I called a buddy of mine who works for a Chevy dealership and this is the number he came up with: 10400442 He says that it includes the brake and accelerator pedal and bracket. Its an assembly, but Im not sure that it has every single part that you would need to completely swap them out.
