Camaro & D1SC@12 PSI
This is 2001 CAMARO WITH PROCHARGER D1SC Xtreme performance forged 347, 228/234 CAM, Hooker LT'S 1 3/4, AIS TRUNK MOUNT METHANOL KIT WITH DUAL NOZZLES,Borla exhaust.
Run#20 570RWHP without Meth and 14-15* timing
RUN#21 619RWP with Meth and with no change to the Tune
RUN#22 656RWHP 540RWTQ with Meth and 19* timing
just to let you know am using VPRACING M3 methanol with power enhancer
LS1 Tech Administrator
Strong power. Nice combo.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
1 Post
So just adding meth you gained 49 rwhp, and then added 4-5*'s timing to it and gained another 37 rwhp, for a total of 86 rwhp by adding meth and retuning. Very nice !!! I don't know much about meth injection other then it helps control IAT's. My question is how much is it going to cost for Methanol to keep the extra 86 rwhp ?? Is Methanol expensive ??
1 Post
Does the meth spray continuously, or only come on as the IAT's start getting too high?? 4 containers a year ?? How many miles do you drive a year ??
Could you drive this car on a 1200 mile one way road trip ??
Thanks for trying to help my uneducated a$$. I don't know if I will ever go FI, but if I do I am trying to find out how much of a PITA meth inj is or isn't.
Again thanks for answering. I can't be the only one that doesn't know. LOL.
His meth system is a premium progressive setup from Alkycontrol. It comes with it's own 2 bar sensor so that it can 'see' boost. The setup mentioned above you works like this: at about 4psi of boost the meth comes on at a relatively low level. It's output ramps up in volume with boost. Basically it's only on when you are "on it". If I went on a 1200 Mile one-way trip I'd drive my truck Old model fuel gallon jugs make a nice way to take an extra gallon along if you think you will really need it.
all runs @ 12 PSI and the CR IS 9.8.
it starts spraying @ 8 PSI and the methanol am using is from VPRACING CALLED M3 which has some power enhancer, not 100% pure like the M1.
tried both and got about 10-15HP more power with the M3.
