Need Help With Reading My Datamaster Info
well i got a reading before i took it to the shop, didn't drive the car, i will do that tomorrow night after i pick it up. i will post up the info but cant seem to copy it in any way. if you know how to do this let me know so i can. well the right side was running a little lean but believe it is because of the EGR exhaust leak but my main question right now is what is normal for knock count? in open loop i am getting in the 170-280 range. Is this normal i do have a LT4 knock mod if that makes a difference. once i figure out how to post it i will and please check back as i will have more questions im sure thanks
o2 voltage should be constantly switching from i believe .100 to .900. my numbers could be a bit off but regardless they should be constantly switching from low to high. low voltage is lean and high voltage is rich.
