ms3 cam only build plans
im almost done ordering all the parts for a cam only build.
heres the list
ms3 on a 112lsa with prc .660 lift valvetrain kit
tsp ported ls6 oil pump
tsp 1 7/8 headers and catted y
c5r chain
ls7 lifters
asp underdrive pulley
head and cam gasket kit
gm oem head bolts(will get arp head bolts when i do heads and intake)
also not that it matters for cam install but i ordered 3.90 gears, slp air lid, smooth bellows, 160 thermostat, fan switch, line lock and some new rims and tires.
is there anything else i am forgetting for install? im having my local tuner do the install and dyno tuning and want to make sure i have everything before i bring it in
heres the list
c5r chain
ls7 lifters
List looks pretty good to me, but but are you changing the lifters for assurance? If your taking off the heads putting in longtubes I think you should save up for some PRC Heads. And as an opinion I would add an underdrive pulley and LS6 intake to the list.
-Joel
-Joel
Yeah man, if your going with a cam, headers, pulley, defintly get an LS6 intake. Their only $300 and make your combo even better.
I'd say with your M6 and gears, guessing at least 400 at the rear.
I have 4.10s, M6, No cam, and am doing 360 with bolt-ons.
Should be a good build you have there, think about putting in some new rear LCA's too for better traction.
Location: Your girl's back door giving her the long stroke while you're at work
My CETA had PRC 5.3s, MS3, FAST 90/90, 150 shot and the usual bolt ons and still had 3.42 gears. On a SOFT launch(3500) it went 7.03 @ 103 with a 1.91 60ft. That was short shifting at 6000 instead of 6700.
The MS3 loves nitrous
