Opinions on dumping a catback
I really like the way Camaro's look without exhaust tips. I have the LM I and am wondering your thoughts on dumping it before the axle. Are there any negative sides to doing this? Thanks!
Thanks for the reply...I've been looking at pics of dumped exhaust systems and have noticed most of the turndowns angled (not directly at the ground). I assume this is to avoid having the exhaust resonate directly back up into the car???
Well, tomorrow I will have a turndown placed behind the LM muffler, right before the axle. I know I will like how it looks; I just hope it doesn't change the sound too much.
heres a vid when I had a 6'' magnaflow dumped. I had a bullet dumped and it had a good bit of drone. with the magnaflow it was not bad at all.
http://www.youtube.com/watch?v=ddKMXRritDM
i had two 16 inch bullets in line with each other dumped and it was fairly quiet, but that was compared to true duals dumped with bullets. also if you dump it then its a little less weight.
