View Poll Results: Will this work for my 408?
Too Small
8
100.00%
Just Right
0
0%
Too Big
0
0%
Voters: 8. You may not vote on this poll
Help! Whats this Turbo for!?!?
come with the 2.5" vband outlets weld in flange included, T3 inlet flanges, T3 inlet gaskets, bolts, oil inlet and outlet flanges
Spec are Compressor TO4E T3/T4 54mm inducer 70mm exducer 3" inlet 2" outlet "57 trim??" Turbine 65mm inducer 56mm exducer Stage III 63 A/R housing.
Is this way too small a turbo for a fully forged 408 stroker?
http://www.racetep.com/turbomatrix.pdf
try this...
GUIDE LINE only....
i would say , at a minium , you would want twin 57 or 60 ish mm ,
with stg 5 turbines , .82 a/r
try this...
GUIDE LINE only....
Still far too small for a 408. The smallest I'd run would be something like twin 3082Rs or 35Rs. The 30s could probably push near 1000whp and spool really nice, the 35Rs would do it at less boost. (correct me if I'm wrong but the APS z06 kits use 35Rs, .63 turbine housing IIRC)
