Replaced Harmonic Balancer now have pulley squeak
I replaced the harmonic balancer the other day and now one of the pulleys is squeaking. I cant not tell which one it is but is sounds like its coming from the right side of the motor. Is their some sort of test to determine which one is sqeaking? I thought it could have been my belts so I put some lube on both of them with no luck.
Double check and make sure the balancer is seated all the way. Get a ruler or something that has a straight edge and make sure all the pulleys are straight.
