LS1 Kit on LT1
Old 03-12-2009, 01:19 PM
kdavis's Avatar
Default LS1 Kit on LT1
would an ls1 kit work on an lt1? are the kits the same pretty much? if not what is different about them?
Old 03-12-2009, 02:05 PM
Nick@HSW's Avatar
Is it a wet nozzle kit? Generally all you need to be concerned with is the jetting on the fuel side.
Nick
Old 03-12-2009, 03:04 PM
kdavis's Avatar
yes its a nozzle. will it need bigger fuel jets or smaller ones?
Old 03-12-2009, 09:23 PM
Nitro Dave's Nitrous Outlet's Avatar
The only difference on the Single nozzle wet kits will be the jetting. What ever manufactures system you have should be able to give you a starting point on the tune up.
Dave
Old 03-13-2009, 09:44 AM
Nick@HSW's Avatar
When going from the LS to LT platform you're dropping in fuel pressure off the factory system. That means you will need to increase the size on the fuel jet.
Nick
