need help
Old 03-13-2009, 09:38 AM
ALEXZ28's Avatar
Default need help
ok some so i got the headers on 2 weeks ago, i raced my car at the strip for the frist time since i got headers, 410 gears , rikan raptors , pulley, ripper shifter, new stage one clutch. the results were very bad my first run was a 10.1 the 2nd run 9.5 and last run 9.7. she is skipping very bad. cant be wires bc i checked them and i had 2 but i had replaced them b4 i went to the strip. its cutting back on me bad. can this be the o2 sensors that are not hooked up right??? i was told it could be the opti.
Old 03-13-2009, 10:35 AM
RamAir95TA's Avatar
Sounds like you've got some burned plug wires somewhere.
Also, get your hands on a fuel pressure gauge and do a fuel pressure test to make sure you're getting adequate fuel pressure.
Old 03-13-2009, 10:58 AM
ss.slp.ls1's Avatar
+1. Check fuel pressure, double check all of the ignition system, wires especially.
