Generation IV Internal Engine - LS3 cam sprocket 4x vs. ls2 2x
Ramairbird
03-13-2009, 02:59 PM
I am doing an L92 swap into my T/A and am going to use Lingerfelter's 58x to 24x converter box, the question I have is I have an LS2 2x cam sprocket(Part # 12576407), but this is a 2x sprocket. The conversion box converts the crank sig from 58x to 24x and the cam sig from 4x to 1x. I guess the ls3's are a 4x sig, which is what I need. Is there a 4x sprocket that also has the 3 bolt mount? The ls3 sprocket is a 1 bolt mount. Lingenfelter told me I need the LS3 4x set up. I wanted a cam that uses a 3 bolt mount, not the one bolt. Will an LS7 cam sprocket fit my needs? Thanks.
rsz288
03-14-2009, 03:28 AM
Yes any 3 bolt 4X cam sprocket will fit. Later LS2, LS7, etc.
12586481.....which i think is correct......
:nod:
Ramairbird
03-14-2009, 11:39 AM
Thanks for the help, that was what I needed.
I was wondering the same thing and called lingefelter and they said the ls2 cam sprocket would work no problem.
rsz288
03-20-2009, 03:53 PM
Just make sure its the later LS2 cam sprocket. 4 bumps. Not 1. all 3 bolt 4x have the same PN.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
