Do I really need a new oil pan gasket?
Old 03-13-2009, 11:45 PM
dannyz's Avatar
Default Do I really need a new oil pan gasket?
Was at napa getting parts to put in my cam, and they told me I have to put in a new oil pan gasket.
I know I need a new timing cover gasket plus a water pump gasket/ crank bolt but a oil pan gasket?
What do you guys say?
Cars only got 60000 miles on it, anything else I need?
Oh, Thanks guys.t chain and gear set also, but that sholud be about it, I think.
Thanks guys....
Old 03-14-2009, 12:06 AM
ExceSSive's Avatar
You do not need a new oil pan gasket, just some RTV.
Old 03-14-2009, 09:10 AM
01ssreda4's Avatar
these metal gaskets are supposed to be reuseable. but mine at 100k did not seal after the cam swap. instead of chasing the leak i just pulled the pan and replaced it. when looking at the factory gasket it was in excellent shape considering the mileage.
Old 03-14-2009, 10:47 AM
SnowmanWS69's Avatar
Sometimes the gasket rips...reusable or not...took me 4 hours to replace the oil pan gasket in my car after I found out the gasket broke....JMO...Pulling the tranny and lifting the motor up to replace a gasket SUCKS!
Old 03-14-2009, 05:30 PM
witry's Avatar
why pull the tranny?
Old 03-15-2009, 10:07 AM
blkbird's Avatar
All you have to do is drop the K-member. First you have to undo a few things, steering rack, a arm, motor mounts, but it comes out pretty easy. I didnt have to pull the tranny. Im about to do mine again cuz i cracked my oil pan somehow......
Old 03-15-2009, 01:12 PM
W es 6's Avatar
+1 don't drop the tranny just the k-member. just did it 2 weeks ago, 6 hours total
Quick Reply: Do I really need a new oil pan gasket?
