87-98 SBC Cam in the LT1
Old 03-14-2009, 12:01 AM
Moderator
BizZzatch350's Avatar
Default 87-98 SBC Cam in the LT1
The cam I got was for a Gen I SBC, I had the dowel changed to the vented opti specs. It is for a hyd roller cam, any other potential issues? From what I have read so long as the dowel is corrected they are interchangeable. I have seen third gen guys use LT1 cams before also, so I don't believe there is a problem, just want to make sure. We compared cams, they both have the same step syle noses, only difference was the pilot hole. This set will be with a 95 Vented opti conversion, SBC Double roller and reusing the factory LT1 cam retainer plate.
Old 03-14-2009, 12:04 AM
95z28camaro's Avatar
True about the 3rd gens using the LT1's, had a buddy do the swap into his '91 TPI. What is the pilot hole you are talking about? Very interesting thread, subscribing.
Old 03-14-2009, 12:07 AM
Moderator
There's a picture on comps web site, basically the hole in the center of the face of the cam. I wish I would have caught this earlier. This sucks
Old 03-14-2009, 12:16 AM
7.0 camaro's Avatar
im running a lt1 cam in my 89 gmc truck that was origianlly a flat tappet cam. but the block was machined for roller stuff. i dont see why it couldnt go the other way around. just change the dowels.
Old 03-14-2009, 12:22 AM
Moderator
They have been changed [dowels], it's just the pilot hole I'm worried about. Some are saying it isn't an issue, other are saying it's an issue.
Old 03-14-2009, 07:05 AM
96capricemgr's Avatar
The ZZ4 cam used to be a popular upgrade in LT1s. Had to watch the pin and have the hole in the nose drilled out to I believe .500" by 1.00" deep to make room for the opti. Don't trust my numbers though, see if you can find a second reference or a stock cam meant for a vented opti and have a machine shop copy it.
I bought my ZZ4 cam already drilled but was told most shops only charge $20.
Old 03-14-2009, 08:16 AM
95 TA - The Beast's Avatar
If the cam does not have the on-center hole in the snout of the crank at the right dimensions, it will not work for 95+ vented optis. You *CAN* still use it on '92-'94 LT1 applications with a non-vented Opti, as those Optis use a simple splined driveshaft and those are not centered on the cam itself, but the cam gear via the previously mentioned splined shaft.
But, since you mentioned a '95+ opti conversion and SBC double roller timing set, you can't use that cam for your application. You need to use the stock timing set, the spline shaft and a unvented opti (or a MSD upgrade for the non-vented, but that still uses the splined shaft).
No-one ever made a simple spline-shaft insert for SBC roller timing sets to use the spline shaft? I looked into it years ago, almost made a few (easy to do with old timing sets laying around), but alas never really found the motivation. Most people just sucked it up and did the full 95+ conversion.
Old 03-14-2009, 08:47 AM
shbox's Avatar
As already stated, the large hole in the cam snout (.500" diameter x 1.0625" deep.) is required for use with the vented opti.
Old 03-14-2009, 08:21 PM
Moderator
Yep, you guys are dead on the money, just no way the opti (vented) will go one with out modification to the pilot hole. Oh well, live and learn.
Quick Reply: 87-98 SBC Cam in the LT1
