NEED HELP.....zr1 rims on 96 camaro ss
Old 03-14-2009, 04:35 AM
METERSF's Avatar
Default NEED HELP.....zr1 rims on 96 camaro ss
My 17x11 zr1 rims won't fit my 96 camaro ss.it hits the bump stop, was I supposed to modify something?
Old 03-14-2009, 07:55 AM
Moderator
davered00ss's Avatar
Cut the bump stops & BFH to the inner fender well. You may have to roll the renders as well.
Old 03-14-2009, 09:43 AM
9t8z28's Avatar
Do exactly what davered00ss said to do. Here is a pic of my car after the mods.
Old 03-14-2009, 12:27 PM
METERSF's Avatar
Sent u pm
Old 03-14-2009, 12:51 PM
METERSF's Avatar
What do people use to cut that stuff off? A cutoff wheel or plasma cut. It?
Old 03-16-2009, 09:00 AM
Xsta Z 28's Avatar
BTW . . . Do not mount the wheel with the axle hanging. If you do that BS mods should not be necessary, althouhg some massaging of the inner wheel well will be needed.
Old 03-16-2009, 11:18 AM
9t8z28's Avatar
No, you still need the clearance for when the axle articulates.
Old 03-16-2009, 01:14 PM
Xsta Z 28's Avatar
Exclamation
. . . I installed 17" x 11" on freinds car, and NEVER touched the bumpstop. 50 mm offset ZR1's . . . .
Unless you are doing Dukes of Hazzard jumps the axle will NEVER move that much where the wheel lip would contact the bumpstop . . .
Old 03-16-2009, 01:24 PM
Z28LS1camaroguy's Avatar
same here just jack the car up by the pumpkin and shouldnt have a problem, i still did the BFH mod just to be safe.
Old 03-16-2009, 02:02 PM
9t8z28's Avatar
Friends car, not your car, it still doesn't matter, your still wrong. The wheel should never, ever be able to contact any part of the body. That is a fact!
Old 03-16-2009, 02:33 PM
Xsta Z 28's Avatar
Arrow
What's your point? Bragging rights?
There is ABSOLUTELY no reason WHAT SO EVER to have to touch the bumpstop installing 17" x 11" 50 mm offset ZR1's.
Why modify something when it does not need to be done?
So the car that I installed the wheels on and has been running for the past nine years with absolutely no issues, is wrong?
Yeah whatever. Lets agree to dissagree on the subject.
Old 03-16-2009, 02:45 PM
ItsNotStock's Avatar
The bump stop will sit perfectly within the wheel as long as you install it by jacking up the rear differential.
Old 07-12-2011, 01:17 AM
solidsnakecsm101's Avatar
Bringing this thing up from the dead.
So im currently running the 17x11's with a 50mm offset. I did cut the bump stops off but now i wish i never did. Anyhow without the bump stops my car keeps bottoming, mind you im at stock ride height, when ever i hit a dip in the road or when i have more then one passenger.
When it does bottom out the fenders, which are not rolled, tend to cut into the tires, 315/35/17's. Is there anything i can to to stop it from bottoming out?
Has anyone ever installed the bump stops back on their car after they removed them????
Any info would be great
Old 07-12-2011, 08:23 AM
whytryz28's Avatar
Im running the same 50mm offset wheels and I only had to BFH a small section of the inner fender and roll the lips.
Do you have an adjustable PHB?
Old 07-12-2011, 11:06 AM
No, im running a fixed panhard bar. Also, i didnt have to bang or modify the inside of the fender wheel area to fit the wheels.
Old 07-12-2011, 11:36 AM
Xsta Z 28's Avatar
I believe there are bumpstops that can be installed on the shock shaft to avoid this issue . .
Old 07-12-2011, 11:45 AM
Xsta Z 28's Avatar
Options:
1: Weld the old bumpstop bracket back on . .
2: https://ls1tech.com/forums/suspensio...-bumpstop.html
3: I cannot find the post on the shaft mounted BS . .
Old 07-12-2011, 11:48 AM
Xsta Z 28's Avatar
Here's the shock one: by Koni
Old 07-12-2011, 11:57 AM
JohnnyBz28's Avatar
Options:
Thanks for that 2nd link. I just cut my bump stops off and was trying to think of a different way to re-mount them.
Old 07-12-2011, 12:21 PM
so does Koni sale a shock/bump stop kit? Or is it a stand alone rear shock? In other words can i buy the thing ready to bolt up?
Quick Reply: NEED HELP.....zr1 rims on 96 camaro ss
