HSW single nozzle Install help
Old 03-14-2009, 06:20 PM
z28_YOU_HO's Avatar
Default HSW single nozzle Install help
Ok well im ready to drill into the bellow to mount the nozzle. Just wanna make sure im not gonna mess this up..On the directions it says there is a kit with a 1/8 drill bit and a tap tool. Is this actually required? Could I just do it myself with my own 1/8 bit? help me out guys!
thanks
Old 03-14-2009, 06:24 PM
jetlag's Avatar
Which bellow are you using? Stock or SLP?
The SLP bellow is easy, stock is not.
I've seen some people drill through the maf end and tap it when using a stock bellow.
Old 03-14-2009, 06:25 PM
z28_YOU_HO's Avatar
I have a smooth bellow. Dont think its SLP though. Custom lol
Old 03-14-2009, 06:30 PM
subhumanzz's Avatar
the drilling and tapping part is for if you are using a metal air intake. you drill right through the smooth bellow. you definitely need to use a bigger drill bit than an 1/8th".
Old 03-14-2009, 06:31 PM
z28_YOU_HO's Avatar
ok nice thats what I figured. Is the nozzle supposed to be sticking all the way to the middle of this intake though? Looks like it wont go in but 1-2 iches.
I should use a bit thats around the same size as the nuts that threads up to the nozzle correct? Then have one side insde the bellow and the other nut on the outside holding on the nozzle? sorry if thats sounds confusing
Old 03-14-2009, 06:32 PM
subhumanzz's Avatar
Old 03-14-2009, 06:34 PM
z28_YOU_HO's Avatar
nice thanks for the pic. Do you remember what size bit you used?
Old 03-14-2009, 06:35 PM
subhumanzz's Avatar
no it doesnt go into the middle of the bellow. just tighten the nozzle as much as you can in the nut. that it all the further it is gonna go. also i dont know if it is required but i put red lock tite on the nozzle retaining nut. i wanted to make damn sure that couldnt come off and go into the throttle body.
Old 03-14-2009, 06:36 PM
z28_YOU_HO's Avatar
Good idea on the thread locker. Thanks for the help time to get back to work
subhumanzz's Avatar
just match the bit up to the size of the nut thats all i did. somewhere around 1/2" i guess. dont hold me to it because i am not certain.
Old 03-14-2009, 07:29 PM
z28_YOU_HO's Avatar
Alright got the nozzle put on. Actually had to grind down my bellow a little bit so the bolt would screw on.
Anyways for the fuel line. Do I unscrew the shrader valve and screw the nitrous line directly onto the fuel rail? Also with it not being wired, the noid will be closed correct? Or should I wait untill everythings wired up to screw in the fuel line?
Old 03-14-2009, 07:41 PM
jetlag's Avatar
Right, power opens it..go ahead and hook it up.
You will need to remove the valve first.
The tool is a couple dollars at autozone.
Old 03-14-2009, 08:16 PM
z28_YOU_HO's Avatar
I cant just unscrew the shrader valve and screw the line right up???? The valve just unscrews to my knowledge. I took it off the other day
Old 03-14-2009, 09:38 PM
jetlag's Avatar
Yes, it does just unscrew...I guess you could use a pair of really small needle nose pliers maybe.......
Old 03-14-2009, 10:19 PM
z28_YOU_HO's Avatar
Lol oh i thought you just screwed it in
Old 03-15-2009, 03:56 AM
subhumanzz's Avatar
you remove the schrader valve with the same tool that you use to remove a valve stem from a wheel. simple take the valve out and screw your line from the fuel solenoid directly onto the fuel rail. do yourself a favor and get a rag and bleed the pressure off of the rail before you take the valve out though.
