Going to the track tomorrow
just wondering if there is any thing else i csan do to save weight or pick up some free horsepower.ill be pulling the back seats and rear carpet tonight and trying to clean her out.
should i go get some race gas?my friend has some 109 octane. mix a couple gallons of that with a couple gallons of 91. would that help?
i dont know. just wondering
Just read the sticky in the FAQ there is a huge list of what you can take off.
Did you empty your washer fluid, Run a 1/4 tank of gas and then bring gas with you 5 gallons. Save weight there.
Rear seat belts
DO NOT PUT RACE GAS IN YOUR CAR UNLESS ITS TUNNED FOR IT. will burn up your o2s and could cause damage to your motor if the motor runs too rich. or to lean.
Good luck.
Rear seat belts
Good luck.
man your welcome. Pull out the passenger seat to that saves your more weight. I have also just run my headers and y pipe and take the back half of your exahust off it weighs alot.
