BIG Giant DRY SHOT folks... how big is big and what is your setup?
I want to know how big a dry shot have you sprayed... what setup (injectors, fuel pumps, tuning, maf or SD etc etc) and what did you think about it. Did you drive the car on the street?
I believe Wizeass is still running the single plane with one of Aaron's elbows. If you've ever seen Aaron's work I wouldn't doubt it could hold a big shot. Why have you decided on just a dry shot? You have already spent alot of money in your engine why not splurge on a stand-alone to be safer?
................ mike i am gonna see what i get this week.. and what will max out my svo 42lbers and a hot wire kit.... we will see might go 60-80lbers and twin pumps.. then go higher.. but i am shooting for a 200 wheel...
I'm no nitrous guru. I just understand the basics behind nitrous, and how quickly a dry shot can find a weak point in your fueling system.
The 42# Injectors that Wizeass has on his car are not sufficient to run a huge dry shot on top of his 408. I've seen them maxed out on a 427 N/A. Unless you have a sufficient fuel system to properly and quickly adjust to the spiked 02 levels you're just doing to break something. Bigger lines/injectors/pump(s)/rails to meet, and of course exceed the threshold required to keep the AFR in a safe level while spraying can add up. Adding the fuel directly is alot cheaper. And imho a wet, or better a stand-alone is cheap insurance compared to a rebuild of an already expensive stroker.
But looking at his web-site he already has a wet-shot that can be jetted up to 300, wtf? I'm so confused.
If you 1/2 *** anything and try to spray a big shot it will break stuff.
Maybe stick to turbos or read more about Dry nitrous.
I'm genuinely curious why you advocate sticking with a dry shot. I'm assuming that's what you're alluding to anyways. At what point would you want to switch?
Yes, but what I'm saying is you're supplying the fuel rather than relying on a systems of sensors. Seems safer is it not?
I see spraying a big dry shot as being half-assed in of itself. How many serious nitrous guys are running dry shots?
I like to stretch my legs outside the FI forum. Can't be cooped up in there too long, and it doesn't hurt to learn something new.
Far from 1/2 assed just kinda new. (sorta like turbos were 10 years ago)
My set up is a all Dry 2 stage direct port.
Never ... there are a few Pro mod guys running all dry, no need to switch if you know what your doing.
Now to answer the question a friend with a 408 went from a 300 dry shot down to a 250 wet shot and ran almost .2 quicker.
I sold my 42lb SVO injectors for a set of 60's and have a pump in the back. Will also put a second pump inline. I had a 200 shot on my standalone setup, but have seen good results out of a dry 200 shot and the 200 shot will allow for easier tuning at the track. Only problem is you need to run more racegas but running he tank with pump and racegas in the standalone wasnt enough per some of the experts.
I was just curious what the differences were and what ya'll thought. I know a dry shot is all about tuning the injectors and PCM and the wet shot is more about tuning the regulator on the standalone and pill jets matching up.
