If you want to run a dual stage 300 shot ................
why are you daily driving a car running on 110 race gas? or are you saying you have a daily driver that will run on 110 octane on the nitrous?
IMO, dont go high compression as it doesnt benefit that much on a big nitrous motor. stick with 11/1 type stuff and you will have a lot of fun with it.
Thats what I was wondering really, is there a thing as too much compression when using nitrous......just like when going with boost.
And yes, I have the ability to just use full time 110 octane, there's stations every few miles around here. So I thought that I wouldn't need to have a stand alone tank system to feed the direct port spray. It'll be ready all the time.
11.5:1 cr won't run properly on 110 octane though, will it? Will I need the stand alone with 110 and just run pump gas full time?
Flat out, highway pull car. Mid and high power is important. Don't have drag tracks around here and its not my thing at all anyway.
I have an LSX iron block and I'm considering a 434ci (4.155 bore x 4 stroke) for more cylinder wall strength than the aluminum resleeved LS2 454ci (4.185 bore x 4.125 stroke). Smaller bore too on the 434 will give me more gasket.
434 iron
or
454 alum
434 iron
or
454 alum
