t400 valve body 1 check ball?
i just pulled the valve body off and it had one check ball. anyone run only one? also one of the gaskets is slightly torn. im not sure what type of valve body it has. how do you know what gasket to get?
Closed ex-Sponsor Account
You should at least 2 checkballs unless you are running an aftermarketV.B. As for the Gaskets, there are only 2 different factory ones. They are identified by a stripe on them for 6 verses 7 check ball cases.
