Tips for cleaning out head bolt holes...?
Hey guys... just pulled one of my heads the other day. I know having any kind of fluids in those bolt holes is cause for a cracked block... soooooo....
what techniques have you guys used to make sure they are good and dry?
I usually roll up some strips of the blue shop paper towels and put them down the bolt holes to soak up some coolant for a bit. Then I do the stock head bolt with channels ground in to chase the threads. Then I hook up a small diameter nylon tube to the end of my air gun and blow out the holes starting from the bottom a few times each. Takes a while but everything comes out. Good luck,
Larry
Larry
oh and as far as my motor goes... -----> https://ls1tech.com/forums/generatio...well-sort.html
thanks for all the tips guys... haven't had a chance to read through them as i'm running late to work right now, but when I get back in i'll look em over
ya i took a stock head bolt ground a few flutes into them and ran it in and out a few times till threads where clean. And for coolant, shop vac with a reducer to 1/8" dia tubing to suck the holes dry.
No one mentioned the drain plugs(one on each side). After you remove those there's to water to worry about. Short of that blast it out with the compressor. You can cut down on the mess by using the rolled up paper towels first. If you're going to spring for ARP go with studs, not bolts.
