383 stroker vibration ?
Old 03-15-2009, 10:27 AM
1st TA's Avatar
Default 383 stroker vibration ?
Going to look at a LT1 car. Guy says it a 383 stroker and that it's developed a vibration. Think theres any chance it could be a balancer problem or more likely an internal problem? Don't know anything about the car yet, just kicking ideas around.
Thanks
Old 03-15-2009, 01:33 PM
RamAir95TA's Avatar
No way to tell without actually driving the car. Could be NUMEROUS things. Everything from a misfire to an unbalanced driveshaft, alignment, bushings, bearings, pretty much anything that moves can cause a vibration.
Old 03-15-2009, 01:37 PM
1st TA's Avatar
The engine is suppost to have 20,000 or more on it so I was looking for ideas. Hoping to pick it up for a good price and see what I find.
Old 03-15-2009, 02:18 PM
onephatZ28's Avatar
Originally Posted by ramair95ta
no way to tell without actually driving the car. Could be numerous things. Everything from a misfire to an unbalanced driveshaft, alignment, bushings, bearings, pretty much anything that moves can cause a vibration.
+2......
Old 03-15-2009, 02:29 PM
Chevyguy358's Avatar
hard to say...just make sure if the motor is internally balanced that the weight on the flywheel/flexplate has been removed or is neutrally balanced. If you look at it check to see if the vibration is all the time or just in gear etc..
Quick Reply: 383 stroker vibration ?
