What's my roller worth?
Well it's technically a roller since you can't drive it lol.
Anyways, it's a Automatic red 1998 Pontiac Trans Am WS6 Clone. 130k on the body.
I'd give the paint a 7-8/10 Needs a good detail. Interior probably a 7/10 got a few small problems I can go into more detail about if needed.
Okay now the engine.
Long story short my LS1 crapped out on me, blew a rod through the block. So I picked up a 5.3 with 20k miles and just got done dropping it into the car. The motor will idle fine, but when you give it any gas it misfires a bit, and wont rev any higher than 4kRPM. I've been told I probably have screwed my grounds up or something.
Transmission pump apparently took a dump when the motor blew as well. This transmission has 40k on it, and its from a 2002 camaro. So, in order to get this car running you need a 50 dollar pump and be able to fix some ground wires I guess.
But to be honest I need a car to get around with, and I need cash to get one. I'm in way over my head with this damn car.
