need help on tires
need help on tires
I ordered a pair of jegs sport star 5-spoke wheels:
rim diameter: 15"
rim width: 8"
studs: 5
bolt circle: 4.50"
back spacing: 5.50"
What size tires would you suggest I go with? I'm leaning towards M/T et street radials but I'm just not sure of the size. Any input would be appreciated
rim diameter: 15"
rim width: 8"
studs: 5
bolt circle: 4.50"
back spacing: 5.50"
rim diameter: 15"
rim width: 8"
studs: 5
bolt circle: 4.50"
back spacing: 5.50"
If you ordered them for a camaro or firebird, thats the wrong bolt pattern, camaros and firebirds are 5 lug 4.75 or 120mm.
rim width: 8"
studs: 5
bolt circle: 4.50"
back spacing: 5.50"
Location: Your girl's back door giving her the long stroke while you're at work
If you did order the wrong wheels, send'em back and get the right size as stated above. If you are dead nuts set on the M/T radials go with a 275/50/15(26" tall) or a 275/60/15(28" tall)
Thanks for the replies. I didn't think that was the right bolt pattern, but when I called them, I told them what kind of car I had, and this was the size they suggested. I figured I should post on here just in case. Thanks again
