$115 cam on ebay
$115 cam on ebay
has anyone ran any of these cams that this guy on ebay is selling? they are regrinds ground off of comp cams grinds. $115 is pretty cheap for a roller cam. was just wanting some feedback. thanks
LS1 Tech Administrator
Dangerous words if you don't have personal experience. The problem with regrinds are they can often wind up below the heat treatment of the original cam. If that happens, then you will experience rapid wear. Basically your cam will go flat very quickly and it could wipe out your motor. Buyer beware!!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
On a flat tappet cam sure, I could see issues with wear but on a mild roller cam? Sure using a monster cam that requires high spring pressure I would be concerned.
Yes even a roller cam needs to be heat treated. If the lobe surface is soft it will fail quickly and likely destroy your motor.
There is a new thread posted on this topic about every other day.
I can show you some ugly photos of hydraulic roller cams that went soft because of bad heat treatment. Looks like a plow went right through the mud.
__________________
Hahahahaha!!!! I had a boy that bought a copy cam of a ms3 off of ebay the car did 307 stock and 288 afterthe cam and tune install. The install was done by pro's and everything check out. leak down, ptv valve seat pressure. Sooooo..... In short after driving it yep wipe out all his lifters and the grooves in the cam where finger deep. If my old laptop didentcrash I would post pics but needless to say you pay for what you get.
