want a recipe for 10 sec cam only nitrous car.
Old 03-15-2009, 10:39 PM
dameter21's Avatar
Question want a recipe for 10 sec cam only nitrous car.
Just wanted to get some basic combos that would net me a 6.90-6.50 in the eight mile. 2000 A4 TA.
It's completly stock except lid/filter.
I was thinking t rex cam, 4400 stall, 3:90 gear in the weak 10 bolt for now, ET streets, NX 150 shot wet, and the common supporting mods(longtubes,ory,pulley, ls6 Intake,)and tube. Any opinions appreciated.
Old 03-15-2009, 10:42 PM
teke184's Avatar
could probably get there with a much smaller cam.
something designed more for the juice would probably benefit more.
call up the vendors....see what they recommend
Old 03-15-2009, 10:48 PM
MASS seller approved
smok'nZ's Avatar
fast 92/92 would help alot
Old 03-16-2009, 06:51 AM
SweetS10V8's Avatar
I second the FAST, but more nitrous always helps if your still too slow....haha.
Old 03-16-2009, 06:58 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Mid to LOW 10's on a 10 bolt..... GOOD LUCK!!
You need to seriously cut a good 60 foot thats in the 1.4 minimum.
As for others I agree, the cam can and should be smaller, 22x/23x max. The stall is fine, bolt ons good, a Drag radial or even a ET drag will be great since the run is done in half the distance.
Also WEIGHT. Time to start cutting it down, that will have a huge impact on EVERYTHING.
Old 03-16-2009, 07:23 AM
slow trap's Avatar
i agree. i know a guy that ran 10s with a 232/234 cam, lts,ory, stall and 150 shot in a full weight car and hitting the juice when the rpms got up enough after he left the line.
Old 03-16-2009, 08:20 AM
02 BLK WS6's Avatar
It took me a 200 shot to get there full weight, but with 3.90's you'll run out of gear with a 26'' tire. I am running 3.42's and going through the traps at 6100.
Old 03-16-2009, 08:32 AM
streetassasin's Avatar
with the H/C set up in my sig Im looking for around a 10.7 on a 150 shot at almost full weight
Old 03-16-2009, 12:59 PM
CARTEK Racing
WS6TransAm01's Avatar
if you get a cam that can get you around 400RWHP reliabley, with a giid spring and a little more RPM, a 75 wet shot should get you into the 10's
A number of years ago, my car was making 396RWHP and 381RWTQ and with a 75 wet-shot I ran 10.701 @ 128
Nitrous was on from 3000-6600 on a window switch and a WOT switch. I would launch at 5K and leave with a 1.40/1.41 60' Powershift at 6200 with the juice staying on, nitrous would turn off at 6600rpm in 4th with about 50' to go before the stripe. I would hit the 7000rpm limiter at the traps with 4:11's in a 12-bolt on a 26" slick.
Old 03-16-2009, 01:13 PM
s346k's Avatar
my buddy has the perfect setup..
2000 b4c. 234/242 on a 110, 4k yank 175 shot. stock long block (241 heads), pacesetter long tubes into 3" x and dumped 4x9 magnaflows. stock ls6 intake, stock throttlebody, stock pulley....a/c, cruise, everything still there. COMPLETELY STOCK suspension. stock snowflake wheels with 255 bfg drag radials with the stock 323 rear. car went 10.7 @ 128 with a very lackluster 60'. absolutely NO weight pulled.
he's got the kit on a ******* toggle switch that he hits about 10' out. the car spins its *** off for like 50' haha. i think the car would go 130+ and easily ET 10.4 if he'd work the suspension and get a real tire on it.
there is your recipe. easy as pie haha.
Old 03-17-2009, 01:34 AM
kmracer's Avatar
yup. pretty standard. 10's are totally doable WITHOUT the spray. just cam only.
Old 03-17-2009, 01:35 AM
kmracer's Avatar
put it this way, if you can get it 7.1 or so all motor, you'll be 6.6 with spray easyyyy.
Old 03-17-2009, 11:51 AM
ls2 bait's Avatar
in an automatic car its really should be that hard. a decent cam that makes good torque (a good old 224 cam makes a nice torque curve) and not something you have to rev to the moon. that way you can get it out of the gate and carry it. a stall matched to your cam specs and a good tire like a hoosier or mt drag radial. let the nitrous come on as soon as the car rolls out and i think its will run 10's all day. if it can make close to 500rwhp on a dyno it will be gravy.
Old 03-17-2009, 12:26 PM
**** then what do you think a a4 with a 3800 stall, 3.23s, mt dr's and an estimated 550-570rwhp should do? (Thats what I think Ill make on spray)
Old 03-17-2009, 01:57 PM
ls2 bait's Avatar
it should run i just know it doesnt take much "dyno" hp to get an automatic car down the track. just proper selection of a few select parts.
Quick Reply: want a recipe for 10 sec cam only nitrous car.
