Disconnecting transmission lines...
Re: Disconnecting transmission lines...
Use an ice pick or a scribe with a 90 degree bend about 1/2 inch from the end. Pop out the 2 wire e clips in the connectors and the line pull right out. To reassemble, put the e clips back in the tranny first, then just push the lines in until you hear them click.
