Rear-end set up tools
Does anyone have rear-end set up tools i.e., pinion depth gauge, case spreader, etc. needed to properly setup a 10-bolt? I run HPDE and autocross and don't have a need for a 9inch or 12-bolt, but would like to change out the gears and limited slip in my 10-bolt. I'd like to this myself as a learning experience and to save a little money.
To clarify...I would like to rent these from you if you're agreeable. Similar to the fellow that rents the cam swap tools.
Thanks,
JC
Thanks,
JC
