help with tranny cooler
ok on the factory radiator. which is the feed line and which is the return line.
the top or the bottom?
and do i want my trany temp sensor before the cooler or after the cooler?
Easy way to remember: the two fluids flow in opposite directions--coolant flows down, trans fluid flows up.
If you want to mount the temp sensor in the cooler line to read max temp, it should go in the bottom line (fluid TO cooler)
so trany flow up. ok sensor in bottom line.
now nother questions. i am putting a tranny cooler on. do i bypass the stock on all together. of do i go trany- after market- stock -tranny or the other way. tranny - stock - after market- tranny.
and why does the sensor go in that set up?
thanks
thanks
Whether you bypass the cooler in the radiator is up to you.
If you use both coolers, put the aux cooler in the line out of the radiator, the top line.
The temp sensor should still go in the bottom line before any coolers.
So it's transmission>temp sensor> stock cooler> aux cooler> trans.
I just remembered this:
As far as operation. I put a new radiator in my one ton truck with a 4L80E so I connected the radiator cooler back into the circuit and didn't really see any difference. I live where it never gets very cold though too. If you live where it gets very cold often you might want to keep the radiator cooler in the circuit.
My A4 camaro has an M6 radiator so I have a stand alone cooler, it seems to work ok.
Of all the vehicles I've built up and driven I can say running it through the radiator cooler doesn't really do much that I've noticed.
i run just the cooler i have i believe a 24 something bm cooler. on a good cruise in almost 100 degree weather trans runs around 200 degrees with some racing... lol i dunno if thats good but its a built trans.. my trans temp sensor is screwwed in the side of the trans so who knows if its accurate
