Is it normal for ls1 engine to burn oil?
Old 03-16-2009, 10:34 AM
raysadude's Avatar
Default Is it normal for ls1 engine to burn oil?
hi guys,
i'm about to pull a trigger on a 1999 camaro z28, i'm really a newb with camaro, and i don't know the nature of the engine, the owner of the car told me that it's normal for the ls1 to burn oil, now his car burn 1 quartz every 3,000 miles
my question is, is it normal for ls1 engine to burn oil? and furthermore is it normal to burn 1 quartz every 3,000 miles..
furthermore, i'm not mechanically inclined, i'd really appreciate it if you guys can give me some advice on how to check the condition of the engine..
if i take the car i'll have to drive it back to oklahoma from florida, so that's going to be a long trip..i don't want to stranded in the middle of nowhere..
thanks in advance,,
Ray
Old 03-16-2009, 11:05 AM
Red96TA's Avatar
yes. they burn oil. for safetys sake and peace of mind though, keep a couple of quarts w/ u in your car.
The following users liked this post:
Darkvaderwins (10-04-2022)
Old 03-16-2009, 11:11 AM
ItsNotStock's Avatar
How many miles are on the car? It's normal for any vehicle to burn oil if the engine is old and tired. What you are most likely referring to is the less than adequate pcv system in these cars. People with 20,000 miles on their vehicles can be a 1/2 quart low every oil change. It's just something people deal with.
raysadude's Avatar
if they burn oil, how many quartz should they burn to be considered a good working engine?
Old 03-16-2009, 11:12 AM
raysadude's Avatar
it's 88k
Old 03-16-2009, 11:20 AM
tasales06's Avatar
i think gm specs says that its natural for their engines to burn 1 quart every oild change or 3000 miles...
Old 03-16-2009, 11:30 AM
smg267's Avatar
Quarts not quartz It is never normal for your car to burn rocks. Mine was about 1 quart every 1.5k depending on how bad I beat the hell out of it. Since the LS6 valley cover swap and not beating the snot out of it, oil consumption has reduced drastically!
Old 03-16-2009, 11:34 AM
Arc00TA's Avatar
My car burned 1 quart every 1k miles until I removed the PCV system, and the motor had less than 20k on it.
Old 03-16-2009, 11:36 AM
SuperSam's Avatar
I check the oil every two weeks...just for peace if mind.
Old 03-16-2009, 12:12 PM
raysadude's Avatar
so we can safely say that any normal engine is burning oil?
because i've seen some people in their ads say that their engine is not burning oil AT ALL...
Old 03-16-2009, 01:48 PM
ZMonte85's Avatar
It is not normal for an engine to burn oil. What makes it normal for an LS1 to burn it is because of the poorly designed PCV system.
I work on BMWs for a living. Some of our current models go 15,000-18,000 miles between oil changes and don't burn a drop.
Old 03-16-2009, 02:24 PM
Did my post just get completely ignored? Lol. I guess it just needs to be said a million times for it to sink in.
Old 03-16-2009, 02:57 PM
raysadude's Avatar
It's not that man...but I've seen people mention in their thread that their cars are NOT burning oil at all..so I'm just wondering if they just make that up
Old 03-16-2009, 03:23 PM
iowackers's Avatar
All cars burn an amount of oil. How much depends on the PCV system, crankcase press, mileage on the engine, compression ratio, naturally aspirated or boosted, etc. 1 quart every 3000 miles may be annoying, but definately not excessive.
Old 03-16-2009, 09:31 PM
dre2013's Avatar
138k here. i add 1/2 qt b/t oil changes...it doesnt burn it, but my rear main leaks like a *****
Old 03-16-2009, 09:38 PM
Pontiacerator
RevGTO's Avatar
My A4 car has used a quart every 2000 miles since I bought it at 33,000 miles. 79,000 now. Doesn't bother me.
Old 03-16-2009, 09:47 PM
raysadude's Avatar
ok, thanks guys, i've concluded that 1 quarts every 3k miles is normal.
Old 03-16-2009, 09:55 PM
davidadavila's Avatar
yea mine burns lots when synthetic is in their
Old 03-17-2009, 10:08 PM
RoDan's Avatar
Get the newer fixed orifice PCV valve, it helped my car a BUNCH. I was eating about a half quart between oil changes. I swapped to the fixed orifice PCV vale, and when I changed my oil the last 2 times, it wasn't low at all. At least not a measurable amount on the dip stick anyway.
Old 03-17-2009, 10:13 PM
GMRL's Avatar
Whats the part number, I may pick one up as well.
Quick Reply: Is it normal for ls1 engine to burn oil?
