Drag Racing Tech
Took 15 lbs out of the stock carpet
Old 03-16-2009, 01:15 PM
01_ram-air's Avatar
Default Took 15 lbs out of the stock carpet
I had to pull the carpet out when I installed the 6 point roll bar in the car. I decided to see if I could get a little weight out of it while I had some spare time on my hands. I slowly did this over time since my car is currently not moving under its own power. I figured that this was a good alternative to spending more money on "light weight" carpet. I've heard some stories where putting in light weight carpet either created a pain with fitment issues or quality of carpet over time. (Not to say that's always the case b/c I've seen people that have had great success with swapping out the carpet also). I just figured I would post this as another way to go if you're on a budget and don't mind putting in the time.
When I first pulled the carpet out...
Then I started scraping all the sound deadening material off. I took a razor and cut as close to the carpet as I could as I slowly pulled the material off. As you can see, in some areas there is actually more then one layer. (My dog layed down on the carpet so I couldn't resist taking the picture)
After I got the majority of everything off I weighed it. I weighed it multiple times by different means and each time it came out to 13 lbs.
However, there was still a lot of material that was glued to the carpet.
This is where I got out my trusty little belt sander. Nothing special.
I didn't try to do this all in one sitting. (Not to say that you can't) I took my time and when I got tired of messing with it, I just pulled it back into the garage and waited until I had more spare time. I actually thought I took more pictures of the different phases, but apparently not. These will have to do.
After spending a while sanding with the belt sander I switched to a little hand sander that worked better for getting into tight spaces. At times, the belt sander was covering too much surface area. There's no way I would have tried the whole carpet with just the hand sander though.
All in all, I probably got out about another 3 lbs of material between the sound deadening stuff and the bottom side of the carpet that I sanded. But, to be conservative I rounded down to 2 lbs. It looks much better now.
Hope this helps someone else.
Old 03-16-2009, 01:43 PM
7 Second Club
ty_ty13's Avatar
it will be loud now!
Old 03-16-2009, 01:53 PM
01_ram-air's Avatar
Originally Posted by keith_AE2010
Way to gut your carpet. Now lets see pics of the cage.
Old 03-16-2009, 01:55 PM
01_ram-air's Avatar
My car is already extremely loud with the bullet mufflers dumped. I drove around for a while with the interior gutted. I got use to it. Putting the carpet back in will only help at this point. Plus, I don't DD the car anymore
Old 03-16-2009, 01:57 PM
Demonicbird00's Avatar
dam you went all out w/ the heat gun i didnt go that far but did take all sound deadening out. also take out that hard rubber out from the trunk area too thats about 3 or 4 lbs
-brandon
Old 03-16-2009, 02:12 PM
01_ram-air's Avatar
-brandon
What exactly are you referring to? Can you show me in one of the pics that I posted?
Old 03-16-2009, 02:18 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea I got about that much w/o heat gun, most just peeled off.
Old 03-16-2009, 02:28 PM
01_ram-air's Avatar
13lbs came out in about an hour.
the additional 2 lbs took about 2 months. lol
Old 03-16-2009, 03:12 PM
Z-RATED94's Avatar
Wow, looks awesome. What cage is that? How fast is the car able to go now, like what time made you need that cage?
An 11.49 or quicker requires a six point bar, such as the OP has. Actually a 5 point, no passenger side door bar is legal.
Old 03-16-2009, 03:16 PM
01_ram-air's Avatar
correct. 11.49 or quicker and you're suppose to have a roll bar.
This is a wolfe 6 point roll bar w/ swingouts. Trust me, pay the extra for the swing outs. This roll bar is good to 9.99 I believe.
Old 03-16-2009, 03:52 PM
where you store the t tops, down in there. theres a "rubber" like mat
i guess your putting the rear seats back in to? if not take out the rear seat belts.
also i removed as much of the firewall rubber mat as well too. thats quite heavy. i only cut what i could reach w/ a knife. if you take the dash out theres more but im not gonna go that far lol
-brandon
Old 03-16-2009, 04:19 PM
01_ram-air's Avatar
Are you talking about something that would have been located here?
I'm guessing it was already removed by the previous owner when the car was wrecked and fixed.
Old 03-16-2009, 05:23 PM
yeha down where the rubber gromet is, is where i was talking about
Old 03-16-2009, 05:39 PM
WS6 SRT-8's Avatar
Wanna get rid of the Boxer? Greatest dogs ever! Oh. Good job on the carpet too.
Old 03-16-2009, 05:47 PM
01_ram-air's Avatar
You would have to pry him out of my dead hands. lol Yes, def an awesome dog. (And, he was a rescue dog from FL Boxer rescue) I got him when he was 8 months old and 55 lbs. He'll be 3 in June and he's a little over 80 lbs now.
Thx.
Old 03-16-2009, 08:54 PM
WS6 SRT-8's Avatar
Here's my rescue dog. Got him from the Columbia animal rescue here in MO.
Old 03-16-2009, 09:29 PM
Deerhunter-Z28's Avatar
I need to do this, nice little writeup.
Old 03-16-2009, 09:40 PM
Cobra Commander's Avatar
excellent idea with the sander
Old 03-16-2009, 09:45 PM
regency's Avatar
damn that was really worth the effort in your car! I dont have enough carpet in the truck to even think about doing that.....lol. I might could get 5-6 #'s if that
Old 03-17-2009, 07:22 AM
2camaros6702's Avatar
You still wont catch me!!LOL.
Looks real good Jared. When is the car going to be back at the track?
Quick Reply: Took 15 lbs out of the stock carpet
