Anyone ever figure out flywheel imbalance problem?
Ever since my Spec clutch was installed we've had an engine vibration and have once removed flywheel,pressure plate, and clutch disc and had it supposedly rebalanced only to still have vibration. I'm being told that GM had a factory imbalance issue and not all flywheels were "neutral" balanced. I was told that the old flywheel had to have had a weight in it that needed to be transferred to new GM flywheel. Both are which are steel. My only argument to this statement is that no two flywheels are the same and how would the weight (if there was one) on one balance the next flywheel the same way. We also wondered if we clocked the flywheel wrong, but I believe it is keyed. I really need to resolve this even if I've already damaged the bottom end. Any help would be greatly appreciated.
Re: Anyone ever figure out flywheel imbalance problem?
When my clutch was replaced with a McLeod single disk, my mechanic had the new clutch and flywheel match balanced to match the setup that came off the car.
The F-bodys don't get this treatment yet the procedure should still be followed to the "T". The only way to get rid of the vibration on the C5s was to get a GM engineer to come to the dealership with the harmonics tester and re-do the balancing procedure.
Mine does the same thing after they installed a new tranny.I dont know about you but it is really bad when cold.And around 55-65 mph. I am going to take it in a bitch about this because it was not doing this with the lemon tranny. Oh yea dI have a spec 3 carbon with spec flywheel.
Thanks for the input. I guess it just didn't make since to me to transfer weight from one to the other since the flywheels wouldn't be the same you would think. I guess if they are factory neutral balanced then the weight is put on after it's a rotating assembly to counter any imbalance in the engine it does make sense.
I wonder if my ASP pulley would throw it all off anyway. Can it be done in the car? I mean, if the engine has to come out, there wouldn't be a stock crank left in anyway I'm sure it can be done, but I gotta wonder how much they would charge me.
They don't have to pull the motor to do the balancing procedure. They do it with the motor in the car. The ASP pulley hasn't been shown to cause any vibrations, etc with the C5s that I know of. I had one on my C5 and when I did my Ram Clutch (402/6130) I followed the procedure above and never had any issues.
