i need new heads and cam
hi everyone i sold my heads off my car and need new ones. lt1 stock ci. every bolton you can get.
i run a 10.79 on my old heads and lt4 hot cam and i would like to get in the
9s with new setup.
can everyone give me some ideas
9s with new setup.
If money was no option, I imagine it would be hard to beat ported AFR's and a custom grind cam.
Don't know what your race weight it, but weight reduction always helps.
What gear, stall (if auto), and tires are you running?
What size shot were you using with that 10.79 run?
Huh? Lloyd and Ai told you to get your milled (non-ported?) stock heads back? Why?
If you had milled stock heads, LT4 hot cam, and spray and you ran a 10.79, ported stockers, beefy cam, and upped shot will definitely drop your ET by .79 (assuming you can keep traction).
problem is though without a core to send them i think its a $600 charge. if you didnt need a stall id say go with a set of trickflows but u said youd have compression problems. of course you can always find stock heads to send in for less then $600
If you have a stock short block, you do not have many options. On average, we see 100-130hp gains with our 200cc CNC'd GM casting, a daily drivable HR, and 11:1 compression. Naturally, that assumes proper installation, adjustment, and tuning. That kind of gain coupled with the highest quality machine work, perfectly consistent ports (read: potential), and quality components represent a value that is difficult to compete with.
Your car sounds like this gentleman's setup with a little more n2o. His ET was reduced by over a second swapping to our complete top-end. Keep in mind, any time you add large amounts of power to a finely adjusted setup you will usually need to do some re-adjusting before you run at full potential.
https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
If you decide to have your stock heads cut, we would advise you to seek out an un-machined set. The deck serves as a reference plane for machining. If your castings were milled a minor amount then they would likely be fine. In any case, if you send them in, please write on them in sharpie what has been done to them previously.
If you have more to spend, our CNC'd packages w/ the new 21deg TFS casting would be a nice step up. It does not appear that we will have castings to machine until end of April however.
Thanks for the interest, guys.
