shot me if you want
shot me if you want
I know that its been ask a million times but i have to. I going to install some longtube headers. Dont know what kind yet. I want to know if the come with bongs for the o2 sensors and an area for the tube that goes from intake manifold to the exhaust manifold. If not i need a solution. Also i might install some apr head studs can the head fit under the cowl panal to slide it on with out lower the k member.
they are o2 bungs lol and im pretty sure every header comes with o2 bungs. You also have to get a set of emission headers for the EGR which you were referring to before or you can just buy some block off plates and get race style headers with no emissions if your area allows it. Also why do you want to put arp head studs on? are you removing the heads for a reason? Studs will definitely make it harder to get them back on if you are leaving the motor in the car
head gaskets are shot i already pulled the heads i thought down the road a turbo or nitro. setup not sure i just wanted to know if i would have a problem depleting that tube. When i mean tube its the metal flexable line that bolts to the back of the intake manifold so i dont confuss you or myself about what im trying to explain 96 stock z28
yeah that metal tube is part of your egr system (exhaust gas return). You can get block off plates for really cheap. Which is a good thing bcs from what I've read on the forum the connections on the headers for the AIR and EGR seem to wanna break. Also studs will always be better than bolts but it all depends on what you wanna do. You could always do bolts now and replace them with studs later if you decide to get real crazy. But with studs if you're keeping it in the car you will have fun trying to get your heads on
That tube he is refering to goes from the back of the intake too the the passenger side exhaust manifold. and instead of buying block off plates i left the egr valve on,so i didnt have to block that hole. then the metal tube i found a plug and put some black rtv on it and slid it into the end that bolted to the exhaust manifold. so i left the tube. that just what i did and i have not had any problems with it. i have also heard other people doing it, so that why i did it that way.
I guess if you are calling me a cheap *** then you are calling quite a few people cheap asses. the only reason i did it is because i was just using what i had available. i didnt fell like paying 20 bucks for something you dont really need. my setup is working perfectly. egr is blocking that hole off and i didnt have to do anything with that and the metal tube is kept there just in case i ever sell the car and decide to put everything back to stock. so everyone has there own way of doing things. and by the way i def am not cheap when it comes to my cars and i am very good at working on cars and all that stuff. so before you call someone a cheap *** maybe you should just keep your mouth shut until you know why someone has done what they have done.
