replacing T/A headlight motors
Search doesn't work and the sticky is about the gear. How would i go about replacing the whole motor? The headlight doesn't make any noise and lights up, just doesn't come up.
Whats the process to swap out the motor?
the 3rd bolt is a painnnnnn to get to. have some wd-40 or pb blaster to help get the arm off the motor shaft. pretty straight forward. took about an hour for both the first time for me with no directions just guessing.
Yup, like therealcreeper said, the only problems you'll run into are the 3rd bolt (it's a bitch), and the damn shaft might be stuck on there really good. I had to hammer the **** out of mine, and then bend it back into shape!
Then when you do the other side, it will be WAY easier than the first!
