General Maintenance & Repairs - Power steering not bleeding properly. 01 Tahoe
boostedinaz
03-16-2009, 11:24 PM
This is for an 01 Tahoe. I replaced the power steering pump on it and filled it about half way with fluid. I jacked up the front end and went back and forth with the wheel like I have always done. The fluid level dropped some but not as much as I expected.
We drop it back down on the ground to see if that worked and of course we have no power steering. I jacked it back up and tried it again this time with the Tahoe running and again nothing.
I check for leaks and any other usual suspects with no luck. Any advice?
