wot shift rpm vs wot shift speed tables
Old 03-17-2009, 01:43 AM
AutomagicLS1's Avatar
Default wot shift rpm vs wot shift speed tables
Using hp tuners or I guess in efi live as well what would happen if you 0 out the wot shift mph tables and let the car shift via the wot shift rpm tables? I have heard lt1 guys do it but I thought id double check
Old 03-17-2009, 08:13 PM
Anyone?
Old 03-17-2009, 08:32 PM
cals400ex's Avatar
i thought if you had the mph tables set lower than the actual mph that the car shifts at then these tables won't have much of an effect anyways. i think if you do this than you can use the rpm table for your desired shift points. someone else better verify this because i am not 100% sure....
Old 03-17-2009, 09:23 PM
DrkPhx's Avatar
Set the WOT upshift mph values super low and set the rpms to your desired shift points. Make sure to set the WOT downshift mph values lower than the upshift WOT mph values. This works perfect for me.
Quick Reply: wot shift rpm vs wot shift speed tables
