heads
Old 03-17-2009, 08:41 AM
snake3126's Avatar
Default heads
i feel dumb for asking but i have alot running through my head. im in the airforce and when i come back from deployment i planned on heads, cam, all the supporting mods. car is a 2000 ws6 m6 mostly stock
question is..do you have to change pistons when you use certain heads? and what heads have you had the best luck with for the ms3 cam?
with streetable hp goals of around 450..should i go with a more aggressive cam?
thanks alot
Old 03-17-2009, 10:03 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Most are running the PRC 5.3 heads with the MS3, I'm one of them. You can hit 450 with the PRC's and bolt ons
